提示这个 <script type="text/javascript">// var L_helpType = "STD_ENG"; // </script> <script src="/t5/forums/postpage/board-id/2170/submitted/feedbacklink.js" type="text/javascript"></script> <script src="/t5/forums/postpage/board-id/2170/submitted/variables.js"></script> <script src="/t5/forums/postpage/board-id/2170/submitted/jquery-1.7.2.min.js" type="text/javascript"></script> <script src="/t5/forums/postpage/board-id/2170/submitted/web.js" type="text/javascript"></script> <script src="/t5/forums/postpage/board-id/2170/submitted/launchhelp.js" type="text/javascript"></script>
The NI-Motion driver software/firmware installed for this motion controller is incompatible with this version of NI Motion Assistant. Please update the driver software using the Drivers and Updates link at ni.com/motion. 请问如何解决 谢谢了! |
已解决! 转到解答。
你安装assistant的版本是多少? 你可以到官网上搜索你安装的assistant版本,例如NI Motion assistant 2.7 然后打开下载页面http://www.ni.com/download/ni-motion-assistant-2.7/2593/en/
在该页面中阅读supporting files里的 release notes,里边有关于与该assistant版本兼容的NI Motion版本的信息。 查看是不是你安装的NI Motion与你的assistant不兼容
