NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
NI ECU MC example run error
When I used the NI ECU MC Tookit  with the example .
it's always show error -301048 occurred  at ****(any example in file "ECUMC")
possible reason(s):
    A DLL required for communication with the slave device(s) could not be loaded . Probably this libary is not installed .
Which library i should install ?
0 项奖励
1 条消息(共 3 条)
2,803 次查看
same error code message. Labview 2017 64 bit
0 项奖励
2 条消息(共 3 条)
2,317 次查看
First off, I realize this is an older forum but I ran into the same issue and it brought me here. So for future people such as myself the DLL is probably talking about a SeedKey which is specific to the hardware you are testing. It acts as sort of a key to access the ECU.
0 项奖励
3 条消息(共 3 条)
1,215 次查看
