机器视觉项目中算法仿真针对图像进行处理时IMAQ Fit Line不会报错 但是加载到实时采集程序中去处理实时采集图片是IMAQ Fit Line总会报错:You supplied an ineffcient set of points to match the minimum score。 错误代码-1074395315 从论坛中说应该降低the minimum score。我将the minimum score改成0,实时采集能会报错,进入模块的坐标没有问题。请问问题出现在什么地方?
I have also recieved this error even though points are fine. Whats the solution
What do you mean by "points are fine"?
It's relative to the score you set.
Try lower your score.
Please refer this, it is one of the known issues.
http://www.ni.com/product-documentation/54691/en/
697023 | — | When using the IMAQ Fit Line VI, if the resulting line is either vertical or horizontal it is possi... |
697023 — When using the IMAQ Fit Line VI, if the resulting line is either vertical or horizontal it is possible to get error: "-1074395315 IMAQ Vision: You supplied an inefficient set of points to match the minimum score". As a workaround, rotate the set of points to a 45 degree angle to find the fitted line.
