求助,想开始学习labview,找了块lab-pc-1200板。安装1200后,开机提示需要驱动。然后上网找,在NI的网上下了TDAQ744。安装TDAQ744后,MAX里还没有1200。求教?谢谢
*** Traditional NI-DAQ (Legacy) Download and Installation Instructions Thank you for using National Instruments Traditional NI-DAQ (Legacy) for PC Compatibles. Traditional NI-DAQ (Legacy) 7.4.4 for PC Compatibles works on Windows 2000/XP/NT. Perform the following steps to install Traditional NI-DAQ (Legacy): STEP 1) Create a temporary folder on your local hard drive and name it TDAQ744. STEP 2) Extract the TDAQ744.zip file into the folder you created in STEP 1. This will create the installation files necessary for installing Traditional NI-DAQ (Legacy). STEP 3) To launch the NI-DAQ installer run the setup.exe program in the TDAQ744 folder. To conserve disk space you can delete your .zip files and the extracted files in the TDAQ744. It is recommended that you keep the extracted installation files in case you need to add features from the Traditional NI-DAQ (Legacy) distribution in the future.
Think you very much.
好象不行,NI-DAQ (Legacy) 7.4.4 不行。我再试试NIDAQ693_English.zip这个。
