NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
无法将veristand的任务部署到RT机
想要在RT机上运行veristand的项目时报错,错误如下:
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307853 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand: The VeriStand Gateway was unable to establish a connection with the target. Confirm that the target is running and that the VeriStand Engine successfully has started. If you still cannot connect to the target, use MAX to reinstall the NI VeriStand Run-Time Engine to the target.
NI VeriStand: Server TCP Interface.lvlib:TCP Connection Manager.vi:7430001
<append>=========================
NI VeriStand: Error 63 occurred at Server TCP Interface.lvlib:TCP Connection Manager.vi:7430001中的打开TCP连接
Possible reason(s):
LabVIEW: 串行端口接收缓冲区溢出。
LabVIEW: 服务器拒绝网络连接。
Target: ***.***.***.***
?Unloading System Definition file...
查阅资料发现可能是在RT机上的veristand engine 没有安装,但是在MAX上对远程系统RT机安装Veristand engine时提示需要如下依赖关系:
veristand engine需要multifuction DAQ 15.0.0
veristand engine需要analog output series15.0.0
可能原因:可能尚未安装用于本终端的该组件的real-time支持。
0 项奖励
1 条消息(共 3 条)
4,570 次查看
请问解决了吗
0 项奖励
2 条消息(共 3 条)
3,934 次查看
0 项奖励
3 条消息(共 3 条)
3,921 次查看
