08-05-2009 10:39 PM
Dear all
I'm a new user of labview. I want to generate 3 different waveform from the file on 3 chanels Simultaneously. Referring to the examples in the labview(there are only examples of single channel in my version),I wrote the file below().But an erro dialog message(the specified resource is reversed.) show up when running it.
my email: tyututy@126.com
waiting for your reply,thank you
我是一个新手,现在想把文件中的数据在3通道中用waveform同步输出
参照labview中的例子,写了下面的程序,可是出错(错误对话框显示:the specified resource is reversed.)
请教高人指点一下
我的邮箱:tyututy@126.com
08-05-2009 11:50 PM
addition:
the parameter need to be set
the physical I/O of channel x: dev1/ao0
the physical I/O of channel y: dev1/ao1
the physical I/O of channel z: dev1/ao2
the structure of the data file is
x1 y1 z1
x2 y2 z2
x3 y3 z3
补充:
文件里的参数需要设定一下
三个通道的physical i/o 需要在框图中分别选择为dev1/ao0 dev1/ao1 dev1/ao2
数据文件的结构为:
x1 y1 z1
x2 y2 z2
x3 y3 z3
08-06-2009 08:02 PM
First, you should have posted this message in the LabVIEW board rather than the LabVIEW Beta version forum.
Second, you should post the error number. I'm sure it must be -50103.
Third, you should search the forums for error 50103. There are hundreds of messages about it. http://forums.ni.com/ni/search?board_id=170&submit
The reason is you can't create 3 separate tasks all using the same clock. You need to create a single DAQmx task that contains all 3 channels.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
