在 04-10-2012 08:41 PM
可以
您好:
想再請問一下,Pin 4 及Pin 5 為輸出+5V電壓出來嗎?
Pin 12 Com 為接地的意思嗎?
在 04-11-2012 10:14 AM
http://www.ni.com/pdf/manuals/373506e.pdf
Page 7
The NI 9411 also has a 2-terminal screw-terminal connector that provides connections for an external power supply.
If you do not have a 5 V power supply to directly power the external device or if you want to simplify wiring, you can connect an external power supply to the Vsup and COM terminals on the NI 9411 screw-terminal connector, and connect the external device to one of the 5 Vout pins. If the external device is already powered, you do not need to connect a power supply to the NI 9411 or connect the +5 Vout pin to the external device.
在Vsup 與COM 有外接電壓源的情況下,Pin4 與 Pin5可輸出+5V的電壓。
假如你連接NI 9411的裝置是需要電壓驅動的,你就可以利用pin4 (or pin5)與COM間輸出的電壓,來驅動你的裝置,這麼一來,就以簡化電路。
謝謝兩位熱心的回覆
