11-18-2015 09:50 AM
It doesn't matter if they are part of the same chip or not, every time I connect a ground to both of them, the error "two voltage sources were found to be in parallel" comes up when I try to simulate. The simulation works when I only try to use one of them, and connect one to ground. But, when I try to use them both, and connect them both to ground, I get the error. Any ideas? Thanks in advance.
11-18-2015 10:50 AM
it would be very helpful to see your schematic.
check internal pin connections in your components properties.
with hope it helps
good luck
Michael
11-18-2015 11:31 AM
True true, here's the schematic as a .jpg.
I'm not really sure what to look for with the internal pin connections. Shouldn't I be able to simply run two of those off the same power and ground?
11-18-2015 11:44 AM - edited 11-18-2015 11:46 AM
thanks for response
it looks OK to me.
It would be better to have your *.ms13 file
with hope it helps
good luck
thanks
Michael
11-18-2015 11:47 AM
Here is the .ms13 file.
Thanks for your help. It seems almost like a glitch with multisim, as this should be simple.
11-18-2015 04:30 PM
thanks for response
it looks like the problem with that specific component's model.
what I have tried was to rebuild the curcuit from the scretch.
after I added the first 74123 - simulation runs ok.
but after a added another 74123 - I have got that message.
with hope it helps
good luck
thanks
Michael
11-18-2015 04:51 PM
11-18-2015 05:06 PM
Hello, thanks for response
well, you could try another one from that line SN74122, SN74123, SN74130 and 74121 if it fits your needs.
with hope it helps
good luck
thanks
Michael
11-19-2015 07:59 AM
Ok, I will try that as a last resort. Do you see any way to get several 74123's to work at the same time?
11-19-2015 08:19 AM
Well, if you tell me what task you are trying to accomplish, I would be glad to help.
with hope it helps
good luck
thanks
Michael
