Multisim and Ultiboard
water level indicator circuit 7 segment does not work
Hi,can help me see my circuit,why the 7 segment can't work?thank a lot !
Message 1 of 9
(5,122 Views)
hello, I have it checked.
a few things -
you have used display with common cathod but needed - common anode.
resistor R1  value is to high - reduce it down to 50..60 ohm or keep the 100 ohm but reduce the ON carrent of LED display,
unfortunately you did not read data of the U2 - 7447  - carefully -  pins 3.4.5 should be in High condition( connected to +5 v through resistor 10 kohm f.e),
I hope it helps
best regurds
Michael
Message 2 of 9
(5,107 Views)
thank you for your reply 🙂
but i follow the changing you told me,but it also can't work. Can u help mecheck what is the problem?thank a lot!
Message 3 of 9
(5,092 Views)
hello,
no problem.
yours LCD display is still Common Cathode, but should be Common Anode as I recommended.
fix it and it gonna be OK
thanks
Michael
Message 4 of 9
(5,088 Views)
Thank you very much,it can work ady
if i want add LED and buzzer in to my circuit,have any suggest?
Message 5 of 9
(5,076 Views)
Thank you very much,it can work already
Message 6 of 9
(5,076 Views)
hello, I am glad it helped.
to your questions -
please formulate exactly what  you are trying  to do.
thanks
Michael
Message 7 of 9
(5,064 Views)
I am not the admin of this forum, but PLEASE do not forget that this forum is dedicated to discussions about problems using Ultiboard and Multisim, NOT problems how to design a circuit. There are lots of forums and newsgroups on the web dedicated to circuit design problems.
Message 8 of 9
(5,047 Views)
ok,thank you for remind
Message 9 of 9
(5,038 Views)
