Multisim and Ultiboard
timestep too small, help!
I am trying to design a simple bubba oscillator, and I am getting a timestep to small.  I have tried a couple of the solutions found here
http://forums.ni.com/t5/Circuit-Design-Suite-Multisim/Transient-Analysis-fails-Timestep-too-small/m-...
and
http://digital.ni.com/public.nsf/allkb/4B99B2CD6C0C3B6A86257205005D58E0
But it did not help or work at all and I am getting pretty frustrated.  Hopefully someone here can help me...
http://dl.dropbox.com/u/27402356/Design2.ms11
Here is my file, I am trying to get a transient analysis from 0.002 to 0.005 seconds, and I have tried timesteps from 1 second through 1e-7, and even when I changed my range to about 10 seconds, and told it to step by 1 second intervals, it still said my timestep was too small.  Pretty annoying...
Any help would be greatly appreciated!
(3,036 Views)
The op-amp model seems to be giving the simulator a hard time. The LF347N component also has the Texas Instruments/LT347_2 model that you can use (under Model manufacturer/ID. section of the Select a component dialog). Replace your component and select this model.
That seems to work as the simulation completes and the circuit oscillates.
Max
(3,016 Views)
