Temperature
is part of many BJT SPICE equations and when you change the temperature in the
simulation, it affects many parameters. Most SPICE models are designed to work
at the nominal temperature so when many parameters are changing at the same
time, will simulation will likely be inaccurate. Some models include
temperature modelling that allows you to sweep only that parameter while
keeping the rest the same, look in the model and see if there are any comments
about temperature.
