06-02-2011 06:38 AM
Can any one help me, how can i simulate 6146B tetrode tube. Folllowing is the spice model for the tube i found on net.
* Filename: 6146s.inc 13/8/97
* Simulator: SPICE 3f4
* Device type: RF beam tetrode
* Device model: 6146
* Author: Duncan Munro
* Date: 13/8/97
* Copyright: (C)1997-2000 Duncan Amplification
* The following parameters are not modelled:
* (1) Heater
* Please note that this model is provided "as is" and
* no warranty is provided in respect of its suitability
* for any application.
* This model is provided for educational and non-profit use.
* Email queries to postmaster@duncanamps.com
* Pins A Anode
* S Screen
* G Grid
* K Cathode
.SUBCKT 6146 A S G K
* Calculate contribution to cathode current
Bat at 0 V=0.636*ATAN(V(A,K)/10)
Bme me 0 V=URAMP(V(A,K)/130)
Bmup mup 0 V=1-(URAMP(V(K,G)-30)/2000)
Bmu mu 0 V=V(G,K)*V(mup)
Bgs gs 0 V=URAMP(V(S,K)*4.5+V(mu)*19+URAMP(V(A,K))/10)
Bgs2 gs2 0 V=(V(gs)^1.5)*16E-6
Bsd sd 0 V=URAMP(V(gs2)*V(at)-v(me))
Bcath cc 0 V=V(gs2)*V(at) - V(sd)
* Calculate anode current
Ba A K I=V(cc)
* Calculate screen current
Bscrn sc 0 V=2.5E-4*(V(S,K)^1.5)*V(gs2)*(1.1-V(at))+V(sd)
Bs S K I=V(sc)
* Grid current
*Bg G K I=(URAMP(V(G,K)+1)^1.5)*(1.25-V(at))*870E-6
* Capacitances
Cg1 G K 13.0p
Cak A K 8.5p
Cg1a G A 0.24p
.ENDS
DATASHEET : http://www.nj7p.org/Tube4.php?tube=6146B
thankyou,
ketan
Solved! Go to Solution.
06-02-2011 08:52 AM
Hi Ket,
In order to be able to simulate using the spice model you have, you will need to create a custom component for your tube. Below is the link which will guide you through creating a custom component in multisim. Just follow the procedure and you should be able to simulate.
http://zone.ni.com/devzone/cda/tut/p/id/3173
Hope this helps.
06-03-2011 03:58 AM - edited 06-03-2011 04:06 AM
thankyou for the prompt response. What footprint should i choose/set?
06-03-2011 08:16 AM
Hi Ket,
You can find similar component in the database and use its footprint to edit it according to 6146B datasheet.
Leila F.
