Multisim and Ultiboard
Reply
replacement of MC1496 in multisim
what is replacement of MC1496/MC1596 in Multisim when used for modulation and demodulation purposes.
Message 1 of 6 (5,251 Views)
Reply
Re: replacement of MC1496 in multisim
Message 2 of 6 (5,204 Views)
Reply
Hi there,
A very simple component which can be used to test modulation/demodulation is the MULTIPLIER component. It can be found in the Sources group and the CONTROL_FUNCTION_BLOCKS family.
I guess you can never find such an ideal component in real life, but its a good place to start prototyping your ideas.
Many semiconductor vendors make analog multipliers and mixers. Have you tried to find these components and their SPICE models?
Yi
Software Developer
National Instruments - Electronics Workbench Group
Message 3 of 6 (5,203 Views)
Reply
Highlighted
I need to mc1496 for multisim
Message 4 of 6 (4,587 Views)
Reply
hey Tien P i reaaally need ur help i've no idea about multisim or simulation but i've tried to fallow everything u've said about simulation of the AM modulation i've create a new component ( MC1496) & i changed the pins 7 & 11 & 9 &13 to NC but still i get errors , so if u look at it i'll appreciate it for ever.
Message 5 of 6 (4,186 Views)
Reply
Hello sensirinatesla...,
Please look at the post mentioned above...
Kind Regards,
Thierry C - Applications Engineering Specialist Northern European Region - National Instruments
CLA, CTA
If someone helped you, let them know. Mark as solved and/or give a kudo. Smiley Wink
Message 6 of 6 (4,165 Views)
Reply
