09-27-2009 05:14 AM
hi i am new to multisim and this forum
i was trying to assemble the following cirsuit of wireless switch im multisim but got stuck in the relay part how do i select the right relay as in the circuit diagram,,,,and also how do i make the load connections please help ASAP ,,,the L and N connections also are confusing
10-01-2009 12:47 AM
Can you please tell me what part do you find confusing in the L and N connections?
As per the circuit diagram you can connect an AC source to it with 230V and 50Hz
For relay use RELAY1C_VIRTUAL component.
It is same as the relay in the circuit diagram.
Hope this helps.
Ujjval
10-01-2009 08:45 AM - edited 10-01-2009 08:45 AM
07-31-2015 01:44 AM
I have use pnp transistor as switch circuit with IR remote signal but output at collector is 0.3v Are the 5v dc relay operate from this voltage
01-01-2018 07:34 AM
can I ask which port on that relay is the comon, NO and NC? sorry. new to this application
