Multisim and Ultiboard
power source in Multisim
I need to make this circuit in Multisim but I haven't taken any design classes yet, so I'm not very familiar with the program. How do I use a current dependent current source in this circuit in Multisim? Are these the same?
(3,922 Views)
You have two options. You can either use the Current Controlled Current Source and modify the Current Gain value to correspond to your problem or you can use the ABM current source and modify the forumla to include the variable that references the node you would like to use to control the soruce. Either should work.
Brian H. -- Electronics & Measurements Product Marketing Manager
(3,898 Views)
