03-22-2011 07:00 AM
hello, I need help on this issue, I have tried to creat a new component(max4249) in multisim with the following spice code, but the multisim return a error message:
04-04-2011 04:57 AM
Thank you for posting your question on National Instruments' forums.
To my knowledge, there is no compatibility issue between SPICE and Multisim.
Therefore, the error you see can have several causes such as a problem in the SPICE code you are using, a wrong wiring of your component, or a missing step during the creation of your component in multisim.
For the first two possibilities, you'll have to check your code and your design to make sure that everything is correctly connected anr/or declared.
For the last option, you should have a look to the following links. they contain information about the best practices to create a custom component in Multisim.
How to Import a SPICE Model Into Multisim
Creating a Custom Component in NI Multisim
You can also have a look to the SPICE dedicated session of the developer zone, which contains a lot of information about SPICE and its use in multisim :
I hope this information will help you.
Guillaume H.
National Instruments France
