05-27-2010 06:23 AM
quite long time ago i use Electronics WorkBench v4/v5, i did like it very much, was very logical approach to design and to Vcc,Vss,GND connections 😄
now I'm trying to run 4060(15V powered) with crystal osc...and I can't, i did browse Documentation/Getting started...haven't found answer there...
so something went wrong...
don't understand 'new' (probably better approach), can't imagine why it get more complicated..
can't spend time to read all manuals to sort it out,
can anybody please explain me what is wrong with this schematic ?
05-28-2010 08:26 AM
Hi
First of all lets start with the circuit itself - do you have any documentation about this chip that you want to simulate? An application note showing a standard way of connecting it would be best. I think the problem might be in circuit configuration itself. For instance you didn't wire any capacitor to CTC input- areyou sure this is correct?
What do you mean by 'new approach'?
Regards
05-28-2010 05:51 PM
05-29-2010 02:50 PM
what more I can say...I've done some exercises,
the osc below was working fine (was generating square wave continuously) until I have placed 4060 on this simulation...now it stops doing so after two pulses:
but on this latest sw_ver + patch I've got working 4060 !!:
but if I connect pin 9 (out of not gate not divided by ripple...) , nothing on ripple -counter outputs presents... oscilloscope input drains-out signal ?
05-29-2010 03:04 PM
here is a pic of it:
any explanation please ?
05-30-2010 05:31 PM
&& here comes latest news:
-when I removed separate gen on nand's:
all I have done is: select group of nand osc and pressed 'delete', even after saving, restarting app...still the same!
for me it look like simulator works when it feels like to work..
06-07-2010 03:37 PM
Could you please send us your circuit for further troubleshooting? Just to confirm your Multisim version go to Help>>About Multisim. What's the exact version?
06-13-2010 11:13 AM
Hello .
I'm french , sorry for my " english" .
Just a remarqu about oscillators and sofware of simulation as Ni and others .
When you make an oscillator , a concrete , in the real life , for exemple an astable oscillator with 2 transistors ,2 base résistors , 2 collectors resistors , 2 capacitors , you have never in these pairs of components the same value , there are never exactly equal ....
With a simulator it's different if you choose 2x 2N2222 , you have 2 components perfectly equals ...the same for resistors , capacitors ...
So when you start simulation , nothing is happening .
Many solutions :
- make this oscillator with components as resistors and capacitors with differents value , exemple one resistor collector equal 4.7 k Ohms and the other with 4.65 k Ohms , the same thing with capacitors ...perhap's nothing happen yet .
- so add a switch in the circuit that you can switch during the simulation , or a pulse ( adjuste the duration with the circuit , one microsecond or more ) with a capacitor in serie in this case on the base of transistor ... so the silent oscillator begin to oscillate .
Before I had difficulties with oscillators as astables , quartz oscillators, as Colpitts oscillators and others , as you on your scheme ......after some nights of reflexion , the top remarks resolve the problem
Sometime just a pulse of +5V during 1 microsecond is enought .
Try , and send me your remarks .
Bests regards .
06-14-2010 05:29 PM
Hi there, yep, not a problem...
_osc.ms11 -working oscillator...
_osc2.ms11 -what happens when u select group of nand based part and delete it...
br. janek_xxx
06-14-2010 05:35 PM
thx for that...
but with those so predictable and well-known circuits (oscillators and especially integrated ones in chip (like 4060)) easy to figure out what is wrong/not right
but when u design something new, on such commercial software....u should relay on something (like algos in properly working simulation software)
don't u think so ?
