Multisim and Ultiboard
multisim
I am using a transformer_ct_rated in multisim.. however I always get a zero output at the secondary. I am a newbie by the way
Please see attached
(4,330 Views)
Hello roel_mathphysi…,
Could you let me know the code of the transformer you are using? I tried opening the file you attached but only see the AC Power. Could you please check this and attach it again?
In the meantime, I would like to show you a couple of links that I hope might help you:
  • Multisim – Component Reference Guide
http://www.ni.com/pdf/manuals/374485a.pdf
  • Electrical Principles - Chapter 8: Transformers
http://www.ni.com/example/14452/en/
  • Improved Transformer Models in Multisim 12.0
http://www.ni.com/tutorial/13930/en/
I would like to know if this information helps. Remember that you must have both sides of the transformer grounded.
Luis C.
(4,238 Views)
