07-24-2015 06:23 AM - edited 07-24-2015 06:23 AM
I am very new to multisim .I am trying to simulate IGBT from International rectifier along with resistor and capacitor circuit. I could find and add the IGBT which i require from the library. I would like to switch on and switch off the IGBT with a driver circuit and the internal clock as input to the IGBT gate driver. Kindly suggest me how can i add or make IGBT switch on and switch off with gate drivers or if anz programmable voltage sources available as in LT spice IV
Regards
Sriniketh
07-30-2015 07:43 AM
Hi Sriniketh
Please have a look into MultiSim examples. I guess the ThreePhaseInverter.ms13 example shows you what you are searching.
The MultiSim examples are located in your public document directory. You should fine the mentioned example under:
C:\Users\Public\Documents\National Instruments\Circuit Design Suite 13.0\samples\Power Conversion\DC-AC
