05-08-2013 08:53 PM - edited 05-08-2013 08:55 PM
I want to use an ideal diode to in the multisim. The ideal diode has a zero forward voltage when undergoing a forward current, and perfectly cut off in backward current. I cannot find the ideal diode model in the components library. Does Multisim have it? If not, could you tell me how to set a diode’s forward voltage very close to zero? It doesn’t have to be exactly zero, a very small number (e.g., less than 0.001V) should be good enough. I tried to set a very small number in junction potential (VJ). But it doesn’t work. You can also find the circuit in my attached file. Thank you.
05-09-2013 12:01 PM
You sohuld find this and many other settings if you use the model maker when using the component wizard. You'll find the option in the section for inputting the model.
