Hello again guys,
I'm having another problem on how to make my counter count 10 states (0-9) only, and I want to use a logical and diode junction, my method is to connect 2 diodes to the corrosponding 1s (which are Q0 and Q3) and the output is connect to UP pin so that the UP stays High no matter what the timer 555 output is and stays so until I use the Down pin by another circuit later, weird things happen when I use the diode method as I don't want to add an entire IC only to do this.
I thought maybe it won't work because the diodes output is considered analog and won't work with 74HC193, so maybe through manipulating the timer555 circuit.
thank you in advance
