09-15-2007 07:47 PM
09-16-2007 08:09 AM - edited 09-16-2007 08:09 AM
O.K. Here we go. Your initial circuit was not working because the oscillator was not putting out anything but 12VDC. Go into SIMULATE>INTERACTICE SIMULATION SETTINGS and the Box that says Initial Conditions. Use the arrow button and in the drop down box click where it says Set to Zero. This will get it working.
Due to the low frequency of the oscillator it takes about 6 Seconds on the simulator timer for you to see the LED's change indicating it is cycling. With the default setup you are going to be sitting there a while wainting for this. So to speed thing up a bit your can go back into the simulator settings menu and down in the middle where it says Set Maximum Timestep (TMAX) Click the first little circle under that and in the box to the right where it says 1E-005 change that to 1E-003.
I hope this help you get your circuit working.
Have a Nice Day
Edit: Your web link isn't working for some reason. Maybe you can try reposting that.
Message Edited by lacy on 09-16-2007 08:13 AM
09-16-2007 10:11 AM
04-22-2010 06:50 AM
Can someone help out here. I'm trying to simulate a bandpass active filter circuit. I connected a function generator to input and an oscilloscope and bode plotter to the output but when I run the simulation it doesn't behave as it should. Infact, I can't even understand the output in the oscilloscope. I've attached the circuit.
I will appreciate any help. Thanks
