01-11-2011 11:47 AM
I just purchased a textbook that comes with a CD containing Multisim 10.1.1. When I try running it is says "Fatal error. Unable to find initialization file." I am running Windows 7 - 64 bit. I am pretty sure this is the problem since it doesn't specify that it's compatible.
If someone could give me some help on what I can do to make this work that would be great.
01-12-2011 10:42 AM
Hello Andy,
Multisim 10.1.1 is not officially supported on Windows 7 (32 and 64 bit), however some customers have been able to install it with no problems. Here are some suggestions:
By the way, is this an evaluation edition? or, did you receive a Serial Number to activate Multisim 10.1.1? If this is for evaluation it would be better to donwload and install the lastest version, 11.0.1. Click here to download this version.
01-12-2011 01:48 PM
Thank you very much. I got that to work.
I had the student version of it. I opened the contents of the CD and manually ran the setup installer. I don't know why in auto run it didn't work.
Regardless, thank you for the help.
