04-07-2010 09:15 PM
i try on many times,but i do not get it by parameter sweep analysis.who can help me? simulate curcuit is in tags
i use multisim10
thanks
04-08-2010 10:01 AM - edited 04-08-2010 10:02 AM
Hi there,
I think you have two problems:
You can reverse the direction of the probe (right click the probe>>Reverse Probe Direction) to have it display positive values that you see in the graph.
Hope that helped.
06-26-2010 03:26 AM - edited 06-26-2010 03:28 AM
Hi Guys,
I have never learned spice programming and NI multisim is my first spice program.
Its very difficult for me to learn everything myself sometimes i loose patience, to read all the manuals.
i have a problem with parameter sweep.
1. How can i set the variables i have plot on x axis and y-axis.
2. i sweeped the resistance from 1 ohm to 10k ohm... and i want the current(y-axis) (vs) resistance(x-axis) graph ..
how do i get it...
i use the same circuit described above.. a voltage source , a led , a resistor, all in series
please help me...
06-28-2010 09:09 AM
Click Simulate>>Analyses>>Parameter Sweep. The sweep parameter (in the analysis parameters tab) is the variable on the x axis. The output variables (in the output tab) are the y axis variables. Play around with it and I'm sure that you can figure it out.
