Hi yalect,
You could follow this Knowledge Base article that explains how to Find the Circuit Impedance in Multisim.
http://digital.ni.com/public.nsf/allkb/9F8D30235DE3EC0186257592006B23A2
So basically, you can place a probe on the wire, so you can have Current and Voltage, and with this you can add an Expresion to calculate the impedance (Z= V/I).
Another option would be to use the impedometer.
If you are using Multisim 14, select File>>Open Samples>>LabVIEW Instruments>>Impedometer>>Impedometer.ms14, copy/paste the impedance meter from that circuit to your circuit.
Carolina
