10-09-2010 12:28 AM
I want to use global connector for a multipage design in MS11. Putting in a global connector everywhere I want a connection on a net seems to work, as does placing on page connectors to nets that have a single global connector elsewhere.
When I export to UB11 I get warnings:
10-14-2010 09:14 AM
Can you post the file that shows this problem? You should remove everything on the design leaving only the things that show this problem, you want to keep your file confidential. Otherwise, go to ni.com\ask and send the file to us.
10-14-2010 01:08 PM
After continuing to work on the design, having windows update, reboot PC, etc. It now does not generate the warnings. I didn't do anything different about how I've been using the global and sheet connectors. I don't know at what pint the messages went away. I guess I'll have to watch for it to crop up again.
David B
