01-20-2011 10:29 PM
I thought I used to be able to import a netlist to my UB project. Now I only have import/dxf function.
If I open a netlist, or drag one and drop it on my design, it opens a whole new design rather than importing it to my existing design.
Is that a function we lost at some rev?
Is a forward annotate from MS now the only way to get a new netlist imported? Or am I missing something?
Solved! Go to Solution.
01-20-2011 11:52 PM
Ultiboard Help:
1. Select File»Open, navigate to the desired .ewnet file and click Open. The Import Netlist dialog box appears.
Note The Import Netlist dialog box also appears when you select Transfer»Transfer to Ultiboard»Transfer to Ultiboard 11.0 in Multisim and save the file that you are transferring as a .ewnet file.
01-21-2011 12:43 PM
When I do this it imports into a new clean design rather than the one I'm working on.
01-21-2011 01:28 PM
Netlist should be *.ewnet. Whether there is at you such file?
* - the file name.
At file opening in Ultiboard the file name will not change.
01-21-2011 01:42 PM
It does change. If my design was ABC, it creates a new one ABC_1.
01-21-2011 02:24 PM
Perhaps, you already have file ABC.ewnet? Then it can be changed, using Transfer>> Forvard annotate...( in Multisim), or to remove an existing file (ABC.ewnet), and then to make import of a new file.
01-22-2011 10:21 AM
Yes that's right. I already have ABC.ewprj and I have a new ABC.ewnet I want to import into it. As you said I can do an FA in MS, but sometimes I just want to load/re-load the netlist. I used to be able to do this.
01-22-2011 10:39 AM - edited 01-22-2011 10:40 AM
After creation new netlist, open old file in Ultiboard and: Transfer>> Forvard Annotate From File...
01-22-2011 11:54 AM
Now that's what I was looking for. That used to be under file/import I think. Thanks.
