Multisim and Ultiboard
Where can I get the SPICE model of LM2907N
I am unable to get any SPICE model for the chip LM2907N . There is one page which discuses about LM2907 . but it is an eight pin configuration http://forums.ni.com/ni/board/message?board.id=370&message.id=5139 . But LM2907N is of 14 pin. National Semiconductor site has no listing of LM2907/LM2907N http://www.national.com/analog/amplifiers/spice_models . Please help.
--- Anirban Hazra
Electrical Engineering Student
4th year , B.Tech
Netaji Subhash Engineering College
Kolkata , India
(6,350 Views)
Hi there,
Someone else was also looking for a SPICE model for the same FV converter. They found one here: http://www.geocities.com/russlk/LM2907.txt. All you need are the lines between .SUBCKT and .ENDS.
Hope that helps.
Yi
Software Developer
National Instruments - Electronics Workbench Group
(6,335 Views)
Uhu , I am searching for the SPICE model of the 14 pin equivalent of the LM2907 i.e. the LM2907N. The SPICE model given there is for 8 pin LM2907.
--- Anirban Hazra
4th year , B.Tech
Kolkata , India
(6,326 Views)
I believe the SPICE model given is for the 14 pin version. The 14 pin version has 4 unused pins. The SPICE model has 10 terminals in all including the power pins which would model the 14 pin version if the implementation is correct.
Yi
Software Developer
(6,319 Views)
I am searching the spice model for the same chip, LM2907N and also LM2917N. The geocities link above is not available anymore. Hope got a respond.
(5,705 Views)
I'm looking for the LM 2917 SPICE models. The link which had been given is no longer available. Pls help.
Ledang
3rd Year IE student
Japan-Malaysia Technical Institute
Malaysia
(4,780 Views)
