03-03-2012 10:43 PM
I am a student learning the basics and simulating basic vacuum tube fundementals. Should I use the AC Voltage Signal somponent or the Fucntion Generator as the source to provide a 455Khz signal? Also when I used the AC Voltage source and grounded it I received an error " Connecting 'Power to Bidirectional'; . I have a DC source for the plate voltage so how do I have isolated grounds? My model seemed to worki correctly in spite of this error, at least viewing the Oscilloscope tracing and gain factor seemed right.
tnx
john
03-06-2012 02:36 PM
You can use either one. The AC voltage source allows you to configure the RMS value whereas the Function Generator allows you to set the peak voltage.
I dont really understand the second question. Can you please upload your circuit so we can take a look at it.
Hope this helps.
