03-14-2011 04:28 PM
Hello guys i will be doing a project on Labview.
In this project, there will be 4 Ultasonic Range Sensors (Probably SRF02). It will be connected to
NI9403 32-Channel, TTL Digital Input/Output Module
I was wondering what to do when i create the labview file, how to measure a distance on LabView using Ultrasonic sensors.
Also if you have any examples i can take a look at them.
Once i've done the programming on the LabView i can connect cRio Chassis and do the test.
Thanks a lot.
03-15-2011 05:18 AM
Hello erkan-uk,
It appears you have posted a LabVIEW and cRIO question under the category of 'Circuit Design Suite' where the subscribed readers are more likely to know more about about Multisim and Ultiboard.
I recommend that you post your question under the forum linked below for a chance of a more useful response. If someone does not post, an NI Application Engineer should pick it later on this week.
