11-30-2010 09:16 AM
I'm laying out a mixture of through hole and SMD components (with Ultiboard 10.1).
I would like to toggle between mil and mm grids; and switch rapidly between grid spacings eg: 100mil -> 50mil -> 25mil -.> etc.
Apart from assigning a shortcut to the PCB Options dialog I can't find any way of doing this with just one or two keystrokes. It's a bit of a song and dance.
Any thoughts please?
Bob
11-30-2010 03:44 PM
Hi Bob,
From the main menu select Options>>Customize User Interface, highlight "Draw Settings" under the "Categories" and there should be a "Select Unit" options under the "Commands" column, you can place this shortcut icon on your toolbar. Uf you want to switch between 10 mil >>50 Mil grid you have to do it in the Options>>PCB Properties>>Grid and Units.
I will create a feature request for this option.
11-30-2010 07:36 PM
Thanks for that info. Tien.
Bob
