03-15-2017 06:45 AM
I am trying to introduce High School students to basic pcb layout with Ultiboard. Their circuits are transferring from Multisim and we are using Through-Hole-Technology so they can solder the circuit when complete.
Is there a way to force the Autoroute to start the traces for every part on the Copper Bottom? It is much easier if all the component legs get soldered on the bottom.
Double-sided designs and vias are fine.
Solved! Go to Solution.
03-16-2017 03:39 PM
Hi Mr_Cz,
I am not sure but I think when you use thru-hole and when the PCB is built, the holes are conductive depending on the footprint, check this link for more information http://digital.ni.com/public.nsf/allkb/2FB28A6C4943A8CA862575BD00522872
Regard,
PedroR
03-16-2017 04:30 PM - edited 03-16-2017 04:46 PM
I am not sure but I think when you use thru-hole and when the PCB is built, the holes are conductive depending on the footprint...
PedroR: Thanks for the idea. That link would be helpful if I don't want pads for the component legs. I do want pads, but I only want them on the Copper Bottom.
03-16-2017 06:51 PM
Mr_Cz,
Check step 5 of the Holes with copper ring section. It says that you'll have metal inside the hole meaning you'll have conductivity between layers (coppers). At the bottom usually, you see a little ring of metal or the component can be soldered to the metal inside the hole.
PedroR
03-16-2017 09:24 PM
PedroR: Your suggestion set me on the right track: The pads of the footprint needed to be changed. Thank you!!
To modify all footprints in a design to prevent traces from originating on the Copper Top:
