10-05-2010 02:28 PM
Hi everybody, I'm new to Ultiboard and trying to throw a quick board together. I'm trying to remove the optical placement targets that appear in the upper left, lower left, and lower right corners of the PCB, since their size is interfering with having the board milled. Is there any setting or option in Ultiboard that I can use to remove them (since they don't seem to appear anywhere in the actual board design on any of the layers)? If it helps, I'm exporting to Gerber RS-274X files. Thank you for your help.
10-05-2010 03:45 PM
These marks are the fidicials. You can remove them in the Global Preferences.
10-06-2010 11:45 AM
Thank you very much.
