01-20-2016 03:43 AM
Anton,
I'll ask a colleague at the university to help me with Ultiboard 13.
Lieven
02-24-2016 01:32 AM
Hi Lieven,
The behavior in Ultiboard 14 is intended. The format has been updated to to follow the Excellon standard fromat, where the decimal points are implicitly defined. So in a sense, it is actually the drill file in Ultiboard 13 that is corrupt. 🙂
/Anton
06-18-2019 08:45 AM
We are having the same problem with 14.0 if you change your output to mm then it will output the files correctly. There seems to be a scaling issue with the inches output for NC drill
