06-16-2011 05:49 AM - edited 06-16-2011 05:50 AM
Ultiboard 11.0.1
After I import a dxf file, is it possible to changes selected dxf lines to an pcb layer (like copper or board outline)?
Just highlighting the layer I want to paste in doesn't work.
Also the option after selecting a dxf line in properties --> position layer doesn't show the pcb layers, only the dxf layers are visible.
06-30-2011 08:56 AM
Hi Lighting01,
You can select the layer that you want to import your DXF as by going to File -> Import -> DXF. Then under Layers, select Merge input Data into existing layer. Then you can select the layer you want to merge the DXF into. After this point, it is not possible to change the layer.
06-30-2011 09:07 AM
Ok but this is the complete file, so now I need a DWG / DXF editor to save the parts / layers to another file I want to convert.
If you do just the DXF import Ultiboard have a hard time. (DXF import seems a bit too heavy).
It does work, but Ultiboard will be slow, save times are much longer etc.
06-30-2011 09:35 AM
Hi Lighting01,
My suggestion to you is that just import the entire design by going to File -> Import -> DXF. Select Import layers from file. This will create a DXF Imported Layer section in your Layers tab. You can use these as a reference and just trace the actual layers like copper top etc on top of this. There is no realistic way to import a complete DXF design into Ultiboard because the DXF file does not contain all the information needed by Ultiboard. After you have finished making the design in Ultiboard, just disable the DXF layers by removing the check mark from each layer.
Hope this helps.
07-01-2011 01:44 AM
That is what I did, but it seems to have a big impact in the performance of ultiboard.
It would be nice to have an option to select the layers you want to import.
