Multisim and Ultiboard
Transient analysis: Voltage gain problem?
I'm suppose to perform a transient analysis with an opamp_5t_virtual using Multism to prove that the values I found for R1 and R2 are the right ones (the circuit needs a voltage gain of +25 dB to be right). I tried to do it, but I don't see how to verify my result. My multisim file is below
(3,374 Views)
Accepted by topic author mariahito
Hello mariahito,
You can check this White Paper with the steps on how to simulate a circuit and check the waveforms of the nodes you select with the oscilloscope: http://www.ni.com/white-paper/10710/en/#toc4
Thanks.
(3,301 Views)
