06-04-2013 11:43 PM
I am using MultiSim 12.0
I am trying to run the example given inside the package.
When I tried to simulate the Buck Converter given in examples, it does not converge. I have tried all forums and made all possible changes in the simulater, but problem does not seem to go away.
Please help me with this asap.
06-05-2013 12:37 PM
That circuit is configured for AC analysis for the purposes of calulating loop gain. It is not meant to run under transient analysis.
If you want to run a transient simulation using an average model of a buck converter, use the slightly modified circuit attached.
06-21-2013 11:47 AM
Hi everyone , can anyone help me please? i get same error , and i cant plot the 2 Curves V(1) Eingang , and V(4) Ausgang --- time ( Transient analyse) , the Grenzfrequez ( limitfrequency is : 828.77Hz
what am i doing wrong and how can i do it right please?
thanks
06-25-2013 09:54 AM
Your opamp isn't powered. There is no connection to the V+ and V- terminals. Take a look at your modified file.
11-18-2013 03:56 AM
Hello, I am trying to run an analysis of this analog VCO circuit but I keep getting the "Timestep is too small" error.
Any sugestions?
Messing aroung with timestep value did not help.
11-18-2013 08:54 AM
ahh, I had the Vdd instead of Vss on IC4, nevermind 🙂
01-20-2014 05:26 AM
When I tried to simulate I get this: "A simulation error has occurred. Would you like to run the Convergence Assistant to attempt to resolve this problem automatically?". But the assistant doesn't revolve the problem.
I get this error: "Timestep too small. Tran simulation canceled".
Please help me.
01-20-2014 01:13 PM
I am simulating your circuit "Primero.ms12" in version 12 of Multisim and I am not getting any convergence problems.
02-25-2016 07:58 AM
I am having the same issue with Multisim telling me that my timestep is too small. I believe that this is because sometimes the wires do not connect to the components, which I have noticed.
Note: I am still in the process of figuring out the circuit, but the goal is to create a counter that goes from 0 to 80 and counts due to the press of a button rather than a clock and has a reset to 0. However, I need to solve the timestep too small error before I can continue adjusting my circuit.
02-25-2016 08:00 AM
I accidentally put my old file in my comment- here is the correct one.
