Multisim and Ultiboard
Reply
This circuit has no power sources: unable to determine the simulation timestep automatically.
Re: This circuit has no power sources: unable to determine the simulation timestep automatically.
I really need you help. I've bought a book with a Multisim 10.1 Student Edition.
When I want to simulate something, I receive the following error message:
"This circuit has no power sources: unable to determine the simulation timestep automatically.
Please add a power source or set the simulation timestep under "Interactive Simulation Settings" to proceed."
I am using Windows XP.
Some time before I downloaded Evaluation Version from NI website and had the same problem.
Thank you for your help.
Best,
Anis
Message 31 of 37 (1,348 Views)
Reply
Highlighted
Hey guys, Lacy and Devon_H,
I was facing the same problem each time I tried running my circuit. And every time I get this error : "This circuit has no power sources: unable to determine the simulation timestep automatically."
So I need to know if you fixed up thiss issue or if I need to reinstall the program.
note I've tried my circuit on my freind's Pc and it seems to functoin normally
I'll attach the circuit and the error msg
Message 32 of 37 (776 Views)
Reply
Can you post your circuit so we can try to figure out what is causing the issue.
Tayyab R,
National Instruments.
Message 33 of 37 (767 Views)
Reply
hey,
I've attached the cicuit and named it error
btw just whant to mension it again that i tried my circuit on my freinds PC  and it worked fine.
Also i tried to uninstall the program from the control panel but it remained, so i tried to erase it from its file locarion but some folders remained there and know i cant even reinstall it :s
Message 34 of 37 (759 Views)
Reply
I do not see the attachments. Can you please try to attach the Multisim file again.
Tayyab R,
Message 35 of 37 (750 Views)
Reply
Hey this is the circuit along with the Error msg
Message 36 of 37 (748 Views)
Reply
this is my circuit, i have to find the equvalent resistane of the circuit , i am using multislim 11.0. Help me finding equvalent resistane. i am having same problem.
Message 37 of 37 (551 Views)
Reply
