12-13-2015 10:39 PM
12-14-2015 01:01 PM
Hi Ckt-builder25,
Which version(32 or 64 bits) of Multisim are you using? The next document tell us that Multisim 64 bits is not supported on Windows 10 of 64bits.
http://www.ni.com/white-paper/52818/en/
Did you already tried the suggestion they gave you? Try uninstalling the software, also run the CCleaner to erase all the files and then install again the SW
Regards.
12-14-2015 01:37 PM
12-14-2015 02:04 PM
Ckt-builder25
Where did you get Multisim? Did you install it using a CD or you downloaded from ni.com?
Regards
12-14-2015 02:15 PM
12-14-2015 04:06 PM
Maybe you will need to perform a force reinstall of the SW, follow the next link that tells you how to do it.
http://digital.ni.com/public.nsf/allkb/ADD22E807D5A12AD862579EC00760F79?OpenDocument
Also, could be better if you try using another installer, may be you can download the installer from ni.com.
Regards.
12-14-2015 10:23 PM
12-14-2015 10:24 PM
12-15-2015 08:26 AM - edited 12-15-2015 08:43 AM
Try downloading the files from ni.com. be sure that you search for the 32 bits version. I think that you can activate both version with the same serial number.
http://www.ni.com/multisim/try/
Can you please mark as an answer my first post?
Kudos welcome!! 🙂
11-01-2018 11:54 AM
Can i ask a question . How to uninstaller the multisim program ??
@Ckt-builder25
