Multisim and Ultiboard
TEST_PT_THT fixed, but slow simulation after
Hello
Im running windows 10, and had a problem with using logic converter - I got the error message with "The component "TEST_PT_THT" could not be found in the database."
I fixed that by changing the compatibility to windows 8.  But now the simulation is really show!  It takes 20 sec, before it begin to run. Almost like it's not responding.
If I change back, and run it "normally" with windows 10, then the simulation start right away.
Any solution?
It's multisim 13.0.1 with all updates installed.
Best regards
Anders
(4,763 Views)
Hi Anders,
This has been passed to our R&D department. For now the only work around is what you have already or to manually create the circuit which the logic converter would make.
Jordan.
(4,736 Views)
