12-01-2010 05:10 AM
Right okay so I am trying to create a custom LED/ Phototransitor sensor symbol for Multisim
I have created the footprint and everything else and then went to assign a symbol to it, only to find that the included Phototransistor symbols are all just single transistors without the LED part.
So I thought, Well all I need to do is somehow join an existing Diode or LED with the phototransistor symbols to create something that looks like this
only problem is, I seem to be only able to edit an LED or a phototransistor, never both at the same time or be able to drag a phototransistor symbol into the symbol editor while editing the LED.
the only way I worked around this was to split the component into 2 sections and use the symbols for either in each section but this is really annoying, surely the symbol editor has a way for you to drag existing symbols into it.
HELPPPP
12-02-2010 07:20 AM
Hi Badger,
Would it be possible for you to repost your question? it seems to have gotten a little bit scrambled
12-03-2010 05:56 AM
I have no clue why it came out like that but yes here it is.
HELPPPP
12-10-2010 03:29 AM
"Right okay so I am trying to create a custom LED/ Phototransitor sensor symbol for Multisim
http://www.radio-electronics.com/info/data/semicond/phototransistor/phototransistor-optocoupler-symb...
HELPPPP"
12-10-2010 03:36 AM
Hi Badger,
What version of Multisim are you using ? Also, the link you provided seems to be broken...
