09-30-2015 06:03 PM
Good day to you all,i want to ask for help in understanding the meaning of (-r-) when i am measuring for resistance of a silicon diode?
10-01-2015 09:26 AM
The -r- reading in the Multimeter indicates an overrange. That means that the actual reading is greater than the Multimeter's setting. For example, if you are measuring a 1.5 GOhms resistance but the Ohmmeter overrange resistance is 1 GOhm, the display cannot show the number and the -r- is shown. The same happens for voltage or current readings.
To change the display settings just double-click the Multimeter and click on Set. Once you change the Ohmmeter overrange resistance to large enough value, you should be able to see the diode's resistance.
10-03-2015 11:00 PM
Thanks a lot Camillo V,it worked well and sorrry for the late response,m grateful for your support.
