04-15-2010 03:19 AM
Hey,
one of the components of my circuit is the FDD5690 ( is an Power Mosfet)!
For the reason that the model is not available in the standart lib, I generated the new component! I found the model ( is attached) and I was making the new component.
I need only to simulate the circuit and as symbol i copied the model from BSP88.
But if i try to simulate the circuit I get an netlist-error!
I´am not sure, but I think there is some problem with the model !!
I hope can help me!
Best regards
markus
04-15-2010 08:40 AM
Hi Markus,
Are you re-using the BSP88 symbol? If yes, you need to add an extra pin on the symbol since the model for the FDD5690 has 4 subcircuit nodes - otherwise you will get netlist errors as there will be an unmapped model node (likely VTEMP in this case).
If this was already done, please post your circuit (if it is not propietary) as this will make it easier to troubleshoot the issue.
04-19-2010 09:01 AM
04-26-2010 10:01 AM
Hi Natasha,
I thought after no more error occurred, that I solved the problem!
But after a check of the hole circuit I am now sure, that my solution doesn´t work!
For a better unterstanding of the problem I added the circuit!
As shown in the pic. the output of the amplifier has 31.6 mA and is not working well !! If i will cut the trace where the black arrow is pointing now, the amplifier is working without problems !!
My opinion is, that I have made some mistakes with the creation of the component FDD5690 because it is not available in the standart lib.
I hope someone can help me!
MZ
04-26-2010 10:05 AM
Could you post your circuit file? I can check to see if there's an issue with the component.
04-26-2010 02:34 PM
The circuit file!!
04-26-2010 02:52 PM
It looks like your model mapping is incorrect.
Double-click on the component, click Edit Component in DB and go to the Model tab. In the Symbol-to-Model pin mapping table, change the order of the pins to:
S-3, D-1, G-2, VTEMP-4.
This order simply reflects the order of the subcircuit pins as specified by the .SUBCKT definition. The pin names are denoted in the commented text below that line.
04-28-2010 07:10 AM
