04-01-2011 07:33 AM
04-08-2011 05:35 AM
04-13-2011 05:24 AM - edited 04-13-2011 05:25 AM
Hello Tamas,thanks for interest in topic.
I exactly want to plot such things like peak voltage or current values vs. R or other parameter - with only one curve on the diagram.Do You or anyone knows, if it possible in Multisim?
raport_maker
04-15-2011 02:25 AM
Hello raport_maker,
I think, using the postprocessor we can make some additional analysis and customized graph. With the postprocessor, you can work with the results of the analysises like the Parameter sweep analysis.
Make the parameter sweep analysis, and then open the Simulate > Postprocessor. You'll be able to see all the results of the analysis, and you can define expressions, and build your own graph. I would recommend also to use the Help, and search for the Postprocessor word, and read the available expressions.
I'm not 100% sure, how to make this R-Vmax graph with postprocessor, but I hope this can help something.
There is also a more advanced option in Multisim: you can use XSPICE commands to build full custom analysis. Simulate > Analyses > User defined Analysis
Or if you use also Labview, there is the Multisim connectivity toolkit available, which can be used to controll the alalysis from labview: http://zone.ni.com/devzone/cda/tut/p/id/7785
I hope, I could help you to get closer to the solution.
I'll try some experiments with the Multisim analyses, and if I got an idea, I'll post it.
Best Regards,
Tamas
04-15-2011 03:15 AM
Hello again 🙂
I think the simplest way is to export the data from the parameter sweep analysis to Excell or Measurement file. Grapher View > Tools > Export to Excell / Save Data to Measurement file
You can plot this graph in Excell - or Labview / DIAdem using the measurement file. You can search for the peak values, and plot it with the different parameter sweep values.
Best Regards,
Tamas
