04-28-2010 05:42 PM
I want to model a misc digital CI only for simulation in multisim. The functionality is PISO (parallel in/serial out) when TE input is high.
Until now I made the spice model as bellow, but no working. Pls. help.
Symbol(ANSI) Symbol(DIN)
################## Model ##################
Model ID : RegHT12E
Model manufacturer : Generic
Model template :
a%p [%tP1?%t:d%t;P1
+ %tP2?%t:d%t;P2
+ %tP3?%t:d%t;P3
+ %tP4?%t:d%t;P4
+ %tP5?%t:d%t;P5
+ %tP6?%t:d%t;P6
+ %tP7?%t:d%t;P7
+ %tP8?%t:d%t;P8
+ %tPA?%t:d%t;PA
+ %tPB?%t:d%t;PB
+ %tPC?%t:d%t;PC
+ %tPD?%t:d%t;PD
+ %tTE?%t:d%t;TE
+ %tCLK?%t:d%t;CLK]
+ [%tOUT?%t:d%t;OUT] %m
Model data :
.MODEL RegHT12E d_chip ( behaviour= "
+; HT12E
+/inputs TE CLK PD PC PB PA P8 P7 P6 P5 P4 P3 P2 P1
+/outputs OUT
+/clock CLK + 12 2 1
+;SYNC
+; TE CLKPDCBA87654321 FFFFFFFFFFFF NF NF NF NF NF NF NF NF NF NF NF NF
+ L X XXXXXXXXXXXX XXXXXXXXXXXX PD PC PB PA P8 P7 P6 P5 P4 P3 P2 P1
+ H X XXXXXXXXXXXX XXXXXXXXXXXX L F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 F10
+;ASYNC
+ X X XXXXXXXXXXXX XXXXXXXXXXXX F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11
+/table 1
+; TE CLKPDCBA87654321 FFFFFFFFFFFF OUT
+ X X XXXXXXXXXXXX XXXXXXXXXXXX F11
+/delay 2
+;input output Rise time Fall time
+ TE OUT 280n 300n
+ CLK OUT 280n 300n
+/constraint 27
+; Name Event From Event To Min/Max Time
+ 'PULSE WIDTH' LH CLK HL CLK MIN 25n
+ 'SETUP' HL TE HL CLK MIN 20n
+ 'SETUP' LH P1 HL CLK MIN 30n
+ 'SETUP' LH P2 HL CLK MIN 30n
+ 'SETUP' LH P3 HL CLK MIN 30n
+ 'SETUP' LH P4 HL CLK MIN 30n
+ 'SETUP' LH P5 HL CLK MIN 30n
+ 'SETUP' LH P6 HL CLK MIN 30n
+ 'SETUP' LH P7 HL CLK MIN 30n
+ 'SETUP' LH P8 HL CLK MIN 30n
+ 'SETUP' LH PA HL CLK MIN 30n
+ 'SETUP' LH PB HL CLK MIN 30n
+ 'SETUP' LH PC HL CLK MIN 30n
+ 'SETUP' LH PD HL CLK MIN 30n
+ 'HOLD' HL CLK HL TE MIN 25n
+ 'HOLD' HL CLK LH P1 MIN 25n
+ 'HOLD' HL CLK LH P2 MIN 25n
+ 'HOLD' HL CLK LH P3 MIN 25n
+ 'HOLD' HL CLK LH P4 MIN 25n
+ 'HOLD' HL CLK LH P5 MIN 25n
+ 'HOLD' HL CLK LH P6 MIN 25n
+ 'HOLD' HL CLK LH P7 MIN 25n
+ 'HOLD' HL CLK LH P8 MIN 25n
+ 'HOLD' HL CLK LH PA MIN 25n
+ 'HOLD' HL CLK LH PB MIN 25n
+ 'HOLD' HL CLK LH PC MIN 25n
+ 'HOLD' HL CLK LH PD MIN 25n
.end
################## Package ##################
Footprint:
Footprint not found in Ultiboard Database
Package type :
Package manufacturer: Generic
Pin Count : 15
Pins information :
Logical Physical Section Type ERC Status Pin Swap Group Gate Swap Group
P1 GRP:A D:INPUT:TIL_RCV INCLUDE
P2 GRP:A D:INPUT:TIL_RCV INCLUDE
P3 GRP:A D:INPUT:TIL_RCV INCLUDE
P4 GRP:A D:INPUT:TIL_RCV INCLUDE
P5 GRP:A D:INPUT:TIL_RCV INCLUDE
P6 GRP:A D:INPUT:TIL_RCV INCLUDE
P7 GRP:A D:INPUT:TIL_RCV INCLUDE
P8 GRP:A D:INPUT:TIL_RCV INCLUDE
PA GRP:A D:INPUT:TIL_RCV INCLUDE
PB GRP:A D:INPUT:TIL_RCV INCLUDE
PC GRP:A D:INPUT:TIL_RCV INCLUDE
PD GRP:A D:INPUT:TIL_RCV INCLUDE
TE GRP:A D:INPUT:TIL_RCV INCLUDE
CLK GRP:A D:INPUT:TIL_RCV INCLUDE
OUT GRP:A D:OUTPUT:TIL_DRV INCLUDE
07-15-2010 11:48 AM
The d_chip digital behavior model is very powerful - and I've created some shift register models from it (I have a HCT595 somewhere on my PC)... but it can be tricky to work with.
If you are not aware, there is a d_chip guide that our R&D team was working on - I would go through the d_chip document that was posted in a previous forums page last year...
http://forums.ni.com/t5/Circuit-Design-Suite-Multisim/models-using-d-chip/m-p/953453
If you can still not determine the behavior please reply back and I will dig into your specific model more.
Patrick Noonan
Business Development Manager
National Instruments - Electronics Workbench Group
07-18-2010 01:49 PM
Thanks. I solved.
There was an inconsistency between chip circuit order params and model template.
The d_chip guide is very valuable. I used that guide to model other complex chips. The problem with the guide are the lack of examples and almost no description of /constraint section for PULSE WIDTH, SETUP, HOLD...
The shift register 12 bits spice model served as circuit part of Holtek 12 bits encoder HT12E.
If anyone interested, now I have available, for free!, multisim models for HT12E and HT12D (decoder), cmos 4067, for simulation and layout, and other helper chip models for simulation only (CMP8= compare 8 pair gates, PIPO4STORE= PIPO 4 bit storage, SIPO12= register).
Grig
07-20-2010 08:46 AM
Grigmodel,
That's great! Yes please post the models for the benefit of all users...
I will check to see with our R&D team to see if there has been any updates to the d_chip guide that was posted last year.
Thanks!
Pat Noonan
07-22-2010 05:13 PM
Yes we added documentation for the syntax for the d_chip device. Under Multisim Help, go to Simulation->Multisim SPICE Reference->Digital and Mixed mode device library->Digital Chip->
07-24-2010 05:15 PM
4067, HT12E, HT12D models. Included in archives: chip's docs, simulation models and schematic examples.
Grig
12-21-2012 08:11 AM
Screenshots for HT12 simulation in attachments.
12-24-2012 01:54 PM
In attachments there are steps to create HT12E and HT12D (Holtek encoder and decoder) for NI ver. 10. Can be adapted to other NI ver.
07-31-2019 03:09 AM
where can i find the HT12E encoder?? please help me with it
