12-01-2014 10:41 AM
Hi there,
Multisim Touch is currently available for iOS. At this point, other mobile OS platforms are not supported.
12-31-2014 04:08 PM
hello Mahmoud_W, on the original multisim, where can i find test vectors such as LD_BAR and CLR_BAR?
02-22-2015 09:03 PM
I am running the app on my iPad and it seems quite convenient. I am working with bandpass filters, but need to run the simulation at a higher frequency than 10K. I have not been able to set the display value high than 10K. Is this a limit or is there a way to modify this value that I don't see.
Jim
05-12-2015 09:15 AM
Hi Jim,
You will need to change the maximum frequency of the voltage source. If you open the properties of the voltage source, you can tap on the Frequency variable and then set the Maximum.
05-12-2015 12:06 PM
08-13-2015 09:35 PM
Is there any way to merge two circuits or to copy and paste part of one circuit to another in Multisim Touch?
01-14-2016 09:53 AM
This app crashes big time, any solution?.
01-15-2016 10:06 AM
Hi Raula,
Can you give us more details? Do you have the latest version of the app (version 1.1.2?) What version of iOS are you using? What were you doing before the app crashed?
Jeff
01-17-2016 12:32 AM - edited 01-17-2016 12:33 AM
Last version 1.1.2 and iOS 8.4 to 9 always crashes after launching, too much people say the same
01-18-2016 11:38 AM
I'm very sorry about this problem, can you confirm what iPad device you are using?
