05-01-2010 12:35 PM
I am trying to simulate a simple multivibrator which I am planning to use it to generate a square wave. I use this circuit:
I think there isn't any problem with this circuit. Almost everywhere I found this structure.
In pratically, the circuit starts to work due to differences of elements. Since circuit is symmetric, it doesn't start to work in simulation. To overcome this problem, I tried to:
* Initailze one of the capacitor
* Change Bf values of transistors
* Take one of them as 2N2222A and other BC107
* Connect a picewise linear voltage source to forward a transistor initially (like creating a one shot pulse)
But none of them worked.
Some of them seems to be worked. But output signal is very different from square wave. (Similar to a noise than square wave 🙂 )
How can I overcome this problem?
Thanks a lot
05-01-2010 02:59 PM
05-01-2010 03:53 PM
