04-02-2017 11:35 AM
I want to analyse a chaotic generator. And I need to make a bifurcation diagram. So I want to make a device, which will change the parameter in cycle and save the peaks of each simulation (of each iteration) and then make a bifurcation diagram. So I want to make it by using c++ code.
So I've found something like "instruction" but it explains the stuff pretty bad (here is the link: http://zone.ni.com/reference/en-XX/help/375482B-01/multisim/gaintestexample/#wp252103). For example, I want to test the GAINTEST model. So I don't really understand the first and the sixth points. Because when I launch the Vcvars32.bat through the cmd nothing happens. But the first point of the instruction claims that I should somehow set the inviromental variables.
And when I launch MAKE_DLL file through the cmd it says "file ifcpec.ifs was not found" (I put the screenshot). And beacuse of that I stuck at the begining.
Please help!!!
04-07-2017 09:20 AM
Hello Max
I am noticing that you put the path syntax between ("") probably that is causing the wrong execution.
Let me show you how it should set up.
Regards
04-07-2017 09:48 AM
Thank you for your reply.
But I'd tried it before and it caused breaking of the way. It met a gap in the way, so it sayd this:
( It just "cut" half of the way and the error showed up) Maybe I use the wrong console, I don't know:)...It's pretty weird
04-07-2017 09:53 AM
And I'm confused by your syntax, cauze I've read, that if you don't put these (""), in case that you have gaps in your way, then there would be an error
04-10-2017 08:29 AM
Hello Max
Let's see the video I made for you in order to make sure you have the folder we are trying to access in the command prompt window.
https://www.screencast.com/t/yao7VsVrTp
Regards
04-10-2017 10:55 AM
Thank you so much for that!
I've got the C file, but not dll:
It claims, it can't create the dll file. And there are errors with "cl" and "link" I don't really understand what it means...Maybe something with environmental variables..I don't know..
