03-29-2016 05:45 PM
Good afternoon! I had a need to add to the database Multisim 10.0.144 many elements. File with description of parameters of elements laid out at http://www.datasheetarchive.com/RS407-datasheet.html. How can I bring a lot of elements of the program in the framework of data elements at once ??? About entry individually, I know, but it is very time-consuming. If the process can unfold in stages. Thanks in advance, Max!
03-30-2016 05:10 PM
There's no way to add multiple components at the same time to the Multisim database, the only way you could do something like this is if they are already included in a user database on another system and import it into yours, but you'd have to already have that user database available, and with the components you desire.
03-31-2016 10:57 AM
Thank you! Are all users add one element ??? .... I can not believe it .... I will specify, just in case ... under the base Multisim 10.0.144 data I mean a set of databases - basic, koraporativnuyu and individual. I am interested in adding any of these bases.
04-01-2016 06:08 PM
I'm not sure I understand what you mean exactly, but as I mentioned if you already have a user database with the components that you want, you can transfer it by following what is showed in here.
http://digital.ni.com/public.nsf/allkb/4C04BF14701766D28625740A0036CF57
I'm not sure if this applies for what you need, but it is the available way to transfer multiple components.
04-01-2016 06:21 PM
RichieTheBard , pay attention to the format of the database file at the specified topic. I have the same situation when there is no such a file, and accordingly there is no database in such a digestible form for the program ... I have a file with the extension .txt or .lib ... actually this is the rub, how to make the database file for Multisim .
