Multisim and Ultiboard
Microsoft Jet database engine Error Code: 3078
Complete message is
The Microsoft Jet database engine cannot find the input table or query 'SYS_USER_MASTER_DATA_SPECIAL'.  Make sure it exists and that its name is spelled correctly.
Error Code: 3078
(6,019 Views)
You should tell us what version you are using and what you were doing when the problem occured
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(6,015 Views)
I also get the same error when starting Multisim 10.1.1. After clicking OK 11 times Multisim is up and running.
I also get the message:
Unable to find the table '[SYS_USER_MASTER_DATA]' in the corporate db.
User fields for master db components will not be saved.
This seems to appear after upgrade from 10.0 to 10.1
(5,428 Views)
Check the paths of the databases in global properties and verify the databases are not set to "read only" in windows properties
(5,423 Views)
Hi Liss,
Have a look at this knowledge base.
Tien P.
(5,417 Views)
